- Mar 26, 2014
- 211
Well, I found that it’s very hard to crank up the z axis on my G0704. I have difficulty reaching up and raising the Z axis by hand (shoulder pain). It takes both hands and is a real pain. I think I need to install a power feed. I have a geared angle drive motor. Both the shaft on the motor and the hand wheel shaft are the same diameter (10mm). 6 revolutions of the crank moves the head one inch. I plan on using either a direct connection or chain and sprocket method. I would think the gear and chain method would allow ratio selection. The motor is a nominal 50 rpm. I thought the gear drive might be easier to install since the motor is not hanging of the end of the shaft. What would you think? Also I thought about an air shock to help with raising the head. Would this be a good idea?
Also I think I need a dro. I know that a full fledged dro would be ideal but is out of my price range. Is the igaging dro acceptable? I don’t have a lot of matching experience and don’t really plan complicated projects.
I appreciate any input.
Thanks
Ken
Thanks
Ken
