Hello, I am curious to see some pictures or hear some advice on how to mount an igaging DRO to the Z axis on my Bolton BT-800 3 in 1 machine. This machine is identical to the Grizzly G9729, among others. I am guessing I am going to have to drill into the spindle or something? There is this plastic cover for the lower bearing, and I can mount to that I guess. I am not excited about the options I have thought about so far. I figured I would check with you all here before diving in. Thanks for your time!
EDIT: Added some pictures. I am thinking of bolting down the sensor block on the machine itself and one end of the bar to a metal (brass or steel?) version of that black plastic dust cover with the grub screw in it. I would leave the other end of the bar free to move. I figure I can make the OD of the metal dust cover oversized and then mill a flat ...
