hopeing this will answer or raise some new questions that have been asked many many times on this forum. iam not a real machinist -that is why i have soooo many ques. still to be answered.
FIRST-- ask urself what am i planning to do with my ''new to me'' vertical mill??
this really is a very important question. iam sure as hell not makin parts for nasa--they got no money to pay me. ok answered that one.
i want to bore holes in metal that r perfectly straight up and down both directions. well i can do this
assuming the spindle and associated bearings are in pretty good shape i can do this and ''retram'' the mill if needed to make them straight - assuming i buy a mill that trams in both directions. NOTE- u cannot do this with all vertical mills.
there is going to be a few ASSUMPTIONS HERE and some missspelled words too. please bear with me.
nqw - i want to cut a straight groove in metal--i can do this too assumuming the ''y'' axis and assoc. parts under the table ain't worn too much hopefully table will move in straight line. i better check this too.
now i want to cut a second groove 90 degrees to that first groove i just cut a minute ago. i can do that too assuming the x axis will move 90 degrees to the y axis. does it ???? i really am not sure. do i have a way of measuring this before i lay down my hard earned cash for my new mill?? i might wanny check this out. tramming the mill all day ain't gonna change this. mabey i was thinkin of making my own machinists squares from scratch. just easier for me to do this if things run 90 degrees to each axis. trammin the quill ain't gonna fix this either.
now i want to drill a deep hole in a thick piece of metal. well first i wil use that short drill bit i have and drill the hole as deep as i can. then i plan to lower the table and use that long drill in my tool box to complete the hole all the way to the bottom . now did the second hole drill exactly on center with first hole ?? --did the table and workpiece move away from or nearer the quill in either direction when i lowered the table and are the ''ways'' upon which the table is guided in the ''z'' or vertical axis in good shape?? i might wanna look at this also. how will i measure this before i purchase this new vertical mill?? tramming the mill each time i raise and lower this table will compensate for a pair of ''worn'' ways '' but this sure is gonna get real tiresome after a while. i better find a way to check this before i make this purchase.
all i really want to do is make stuff and enjoy my purchase--i sure as hell don't want to ''retram that quill each time i move the table and vise up and down.
or each time i move the work piece up and down in the vise.
ok--i hope i raised some interest here --these are MY IDEAS of questions u should ask urself --before u ''lay ur money down''
let's hear what other's have too say bout this.
i will get off my ''soapbox'' now --just sayin. please be kind.
re steve in montana --ps where it is now 10 degree below
zero---u got propane??
