You Don't *need* A Lathe
A
Andre
Forum Guest
Register Today
When I got my Anschutz 1907 in a 1914 stock (Match 54 action with lighter barrel) the bolt cam surface was not broken in, so when loading CCI standard I had to hammer on the bolt to chamber. Long story short I made a extended bolt handle to replace the OEM 3/4" plastic ball.
I did not have a metal lathe at the time, so I hacksawed a piece of 3/4" hot rolled and put it on the wood lathe and started "Turning" it with files. I then centered it up in the drill press and drilled and tapped it for 1/4-20. It fit right on, so I polished it and it's been working great for over a year now. Although I used a wood lathe I could've drilled and tapped the hole first, put some 1/4-20 allthread into the drill chuck then screwed on the blank and turned it with files on the drill press.
You do not *NEED* the right tool for the job, just use your imagination and you can get the job done!!!
Oooooh, an Anschutz....very, very nice! Way out of my price range (not to mention dang near impossible to find here in Canada even if I could afford one) but still love looking at them regardless!
Nice work on the bolt knob...:cool:. When I was working/training last winter with a machinist/gunsmith buddy of mine, he had me make several 1-piece bolt handles w/knob using mostly just a file. Turned the shaft "close" to size in the lathe, but had to finish it and form the knob using nothing more than a file(s) and various grit sandpaper (while spinning in the lathe, of course). I thought he was nuts at first, but I did learn how to work a file properly, which I probably never would have without that exercise!
I used to occasionally turn things on my drill press using files or even homemade tool bits attached to the vise's moving jaw, but a drill press spindle isn't made for side loads so it's not a real good idea. Furthermore, the side load kept loosening the taper mounted drill chuck and it would fall off while I was working.
Nowadays, still not having a lathe, I turn short parts in my mill.
You can get older/used Anschutz rifles in the states, I'm sure with a PAL (Or FAC?) you could get one sent your way. Even the old ones are scary accurate, you should see the one Lones Wigger used to shoot; broke countless records. What kind of shooting/training did you do?
I would've liked to see a bolt hand made with a file, that sounds real interesting!
I have turned a few parts using my Mill. Larger parts however require a bit more forethought.
Nice work one the bolt handle but if you ever meet my girlfriend do not tell her it's possible to make do with less. I almost have her convinced a third lathe only makes sense
The pal isn't the problem the $250.00 "fee" charged on every firearm being exported out of the US is what makes it prohibitively expensive! Thanks for that whole "free Trade thing" ???
I sincerely hope nobody's wives are reading your thread! We've all put a lot of time into convincing them we do in fact HAVE to have a lathe. Great job, just don't spread it around lol.
Andre: Very nice work.
Mike E: The wife issue is very simple. Give them the choice of activity they would rather you participate in...either machinery or (insert less desirable choice for wives' here)...no third choice. :)
A lathe would be a super cool addition to the equipment family. However, with no space for one, I can make do with a rotary table and a 4 jaw lathe chuck. I also plan to set up a jig so i can polish a drill press post, using the horizontal part of my mill. It's great to hear of alternative ways to machine parts.
