- Jul 1, 2012
- 1,356
I was just down in Oklahoma working for a company with several older machines. They asked me to do some PM (preventative maintenance) on their machines. I started on a 1941 year 36" Bullard vertical turret lathe. They are a job shop and rebuild oil refinery and power plant valves.
They weld the worn areas, bore and face and restore these valves to new tolerances. They have 5 Bullards and 1 King VTL's. They are swamped and they just hired a maintenance man. What we did was to first clean the machine (s), wiped of the years of grease, dirt and chips. I used industrial soap like Simple Green and on the stubborn crud I used paint thinner, a putty knife and Scotch-Brite.
After cleaning the ways I hand and power scraped the exposed flat ways that had lost all the old pockets and 1/2 mooned oil flaked them They said the machines were still cutting straight but they could not see the scraping marks any-more. This is a typical scenario I see in many machine tools everywhere.
I also took off the way wipers and cleaned them and reinstalled them. Then I took a .001" feeler gage and tried to slide it under them, several were worn and it feel in. I removed them, cut some o-rings in 1/2 and slid them in behind (shimmed out) the old wiper and it's holder and that worked to press it against the ways. I then checked to be sure all the grease fittings worked and took grease, stoned off any burrs on the ways and table top, etc.
While I did this the new maintenance man cleaned the flat belt (we ordered a new one too), drained and cleaned the transmission oil, adjusted the feed and rapid clutches and tightened the gibs. The machine hopefully run another 71 years with these simple steps. Many times this is all a machine needs. There are many reasons a machine wears and many times it's because of poor maintenance or the operator uses a air hose to blow clean the ways and that blows the chip and dirt under the way wipers. Many times when I see a air hose hanging on a machine I look at the owner and say "Turn up the pressure, so you have to call me sooner"
Many times machine are cutting straight but start get stick slip which is a jerking motion when you move the parts. This is caused by to much friction because the oil pockets are gone. A simple cut and flake and some PM will make a machine last longer. A whole lot cheaper then a rebuild. Remember the TV commercial "You can pay me now (simple PM) or PAY ME LATER (complete rebuild).
