During the 30's and 40's and in fact right through to the final production in March, 1981, Atlas lathes were sold without a motor. Atlas also sold motors but you had to order the motor separately. However, the factory recommended minimum was 1/3 HP @ 1725 to 1750 RPM. The maximum recommended for the 3/8" bed 10" and 12" was 1/2 HP. The only way to find out what your 10" had in the beginning would be to look up the original invoice. If you didn't get the customer's copy of that, the Atlas copy was destroyed probably in the 1960's. So there is no way to tell. If a motor came with your 10", it may be the original. If one didn't, then use a 1/2 HP 1725 to 1800 RPM either single phase Capacitor Start or 3-phase with either a 48 or a 56 frame size, depending upon whether your motor pulley (if you have one) is for a 1/2" or 5/8" dia. shaft. If possible, go with the 5/8" shaft as it is the standard today. Or of course you could go with a 1/2 HP DC motor if you are into that.
