weird - no back gears but it still has the spindle and countershaft belt pulley. I wonder if the chain drive is for back gear, with some way of disengaging the chain drive (or spindle pulley) to swap between back gear and direct drive. Can't see the point of having both belt AND chain driving the spindle.
While trying to figure out the drive system, I came across the answer in the description, "Has been reconfigured with chains to function better." I reckon he figured it would.
