Yard windmill project for wife's Christmas present
mattthemuppet2
H-M Supporter - Gold Member
Sep 28, 2013
4,395
Starting a bit late this year as job hunting and work kept me busy until the beginning of this week, but here's my build thread for my wife's Christmas present (previous years were Full Metal Chicken, The Nutcrusher mk 1, stainless steel pestle and mortar amongst others.
Going to use an old fan blade that was in my last auction lot. Cleaned it up and gave it a couple of coats of white to prime it
This is the fan hub that's going to bolt up to the fan. The threaded on cap will retain it on the bearings which will be held on the shaft with a circlip. I turned a simple mandrel so I could do the outside of the two pieces together
My current fave chamfering and facing tool
The fan shaft. End is turned for the two bearings (6902 I think, from one of my bike wheels) and a circlip. Finally got to use the full length of my lathes bed to sand and polish it. Turned, parted and chamfered the end
Better finish up my coffee and get back to it, time is a ticking!
Very nice work.
And that's a nice chuck.
Regards
Thanks and thanks :) It's a Pratt Burnerd adjust tru, lovely to use.
Finished up the top bearing cap and drilled/ framed reamed it for the fan shaft
Need to make a front cap for the fan so the paint has a chance to dry in the sun.
Front cap made, lovely finish, seems a shame to paint it :)
Black base coat is drying (sort if) and I'll give it a couple of brown top coats after my coffee. Then it's just a matter of jb welding a couple of bits together and final assembly. Looks like I'll even have time to assemble my ginger bread truck today!
