- Mar 28, 2016
- 3
I've got an old rusnok mill mounted on a different base I can't recall at the moment. I don't do much work on the mill but it comes in handy when knifemaking. My problem is milling left to right. If I piece that's known to be flat/parallel mounted on the table or on parallels in the vice and I try to take say .010 off the top of the piece the further I move to the left the more it takes off. I can't make a flat parallel piece. In my mind it's not a tram issue because if the head is tilted 45° it will be filed the same 45 all the way across the table and not dig in further left to right. Any ideas? I've tried you tube videos and such but don't see anything that deals with this issue. I'm just learning as I go.
