X icon box is lit up green and I get no response when moving axis.
RaisedByWolves
Mangler of grammar, off my meds.
May 7, 2023
2,154
Did the initial configuration and set steps at 5080 on both axes, axsis?
Box around X axis icon is now lit up green and I get no function.
Box around Y is not lit and works as normal.
Prior to doing config everything worked, but was reading at 10,000 res.
Green outline means that you have audible warning turned on that axis. It will not block the readings. Check your configuration, specifically input axis labels.
enable axis is on.
Axis label just shows X, should there be a value or input?
Looks the same as Y.
ETA: I swapped the connectors to eliminate it being a scale issue.
Its on the tablet side. Obviously user error.
I'm in the middle of nowhere right now with spotty internet.... Will post a link to the manual once I'm back to civilization.
Since Im just getting this setup Im wondering if delete/reinstall would be the easiest route.
ETA: Ditched that config and entered a new one, all better now.
