I have a 150 Servo that is on a mill that has seen little use. The servo will not do anything. Turning on the switch and the power light does not come on. I took it apart and every thing in side looks fine. Does anyone have a schematic for this servo? I think it is not getting power as I used multimeter to check continuity between the plug and then where those three wires connect to the circuit board and on off switch. Cannot get continuity on any of the wires, and I have a hard time thinking the factory plug is bad or the cord is damaged as it looks like new. Any help or ideas greatly appreciated
if I should be asking this question on another forum in the group, please advise which forum would be the correct place.
