WTB: Encoder (or complete servo) for Hurco CNC
gr8legs
Rest In Peace
Oct 31, 2014
444
Well, MillZilla (my Wells-Index mill with a Hurco KM-3P CNC retrofit) has thrown a shoe and lost her mind on the Z-Axis.
A bit of troubleshooting reveals a non-functioning encoder on the Z-Axis Stepper motor.
Apparently Hurco used several different motors/steppers for their CNC and I need to replace the encoder with something compatible. Servo motor are Reliance Electro-Craft Model E727, P/N 727-903-0862.
Photos show servo in installed position and close-ups of encoder P/N (Renco? 77678-038), and encoder internals.
Anybody got a spare unit or a wrecked out mill with an intact servo? I am definitely willing to pay a reasonable sum as without this widget my CNC is dead, dead, dead :)
Thanks in advance
Stu
HurcoEncoderServoZ_Axis.jpgHurcoEncoder_P_N.jpgHurcoEncoderServoLabel.jpgHurcoEncoderBoard.jpg
American Airlines wants to cut costs by "simplifying" maintenance". Passengers can help by watching for falling parts
Stu I wonder if that encoder could be repaired? How hard is it to remove from the machine? I'm only 1 state away
Those two ICs are cheap and readily available. If you can send it to me I may be able to revive it for only parts cost and maybe a couple bucks labor
You might be able to stuff it into a small priority box
-Mark
If you can figure out what the line count is, any 4 channel quadrature encoder will work. I have not be able to find the specs for that particular part number.
Progress (?) Report:
As the OP on this thread I spent a good deal of time twiddling with the servo and diagnosing encoder operation and associated wiring.
I determined that the processor was receiving 'count' pulses but not once-per-turn 'index' pulses - so perhaps just a loose or corroded connection somewhere between the encoder and the CPU was the problem.
Repeatedly removing and replacing the inter-board connections - perhaps cleaning them up in the process - (a tried and true troubleshooting technique) eventually returned the encoder to operating condition.
Whether this is actually a 'fix' or just a mirage is yet to be seen but for now it is working again and I am back and running. Good thing too as I was halfway through milling 1.392" diameter holes through two pieces of 1.5" CRS.
Thanks to Mark and Jim for the advice and encouragement!
Stu
Great news! When you get a chance go back and clean the connectors more thoroughly, probably keep it going forever
Chips seldom just fail for no reason, connectors are always prime suspects
-Mark
