Wrench For 5c Block
Brnoczech
H-M Supporter - Gold Member
Nov 13, 2012
50
I had a square block for holding 5c collets. When I first tried to use it I found that I had not tighted the nut enough at the back of the collet (hand tightened) and the part ended up moving in the mill. I didn't have a spanner/pin wrench but did have some aluminum rounds, so I made a wrench. Also redrilled the holes in the nut since they were out of line all the way around. Simple project but works well. Pictures below.
That's what you do when you need a tool, make it.
