Wrammer
Cadillac STS
H-M Platinum Supporter
Jul 20, 2012
1,255
This is not a new product. Very common for a Bridgeport and i have one for mine. With the machine with a drawbar for tools you need to use a wrench to loosen the drawbar and then a hammer to tap the bar down to release the tool. I made my own for a different smaller mill I have, same problem and I didn't want to keep using the wrench and hammer every time I changed the tool.
The wrench part needed to be 12 point to be easy to get on, not need to fiddle with 6 point getting exactly on for just loosening. And the hammer part needs to be soft so as not to hurt the drawbar. I had the bronze stock and used that, brass is usually what they are made from.
Wrammer = Wrench + Hammer
The 12 point socket is just from the many partial sets I have like most guys. I bored the hole in the bar with the lathe and press fit it very tightly with my 12 ton press. Forgot loctite but it is very tightly pressed in.
I never used this for handles before. "Plastidip" comes in a can and you dip the handle in and it comes out with a plastic covering for a handle. Can re dip as much as you want. Worked nicely for this.
