- Sep 24, 2020
- 2,015
Need a larger pic !!!!!!!!!
Seems like the motor mount is a one off type.I'm sure there are much cheaper generic parts available for restoration with a little research. Whether it's worth it is totally up to you. Mike
No problem, a machinist can handle that. Do you know any?Seems like the motor mount is a one off type.
Restoring is pricey with original-equipment parts, but... a micro drill press doesn't takeI was given this drill press, missing motor and pulley, belt, and chuck.
Chuck is $500, motor is $500, belt and pulley are about $50.
Not sure it is worth fixing........
Not sure where I can find a 30k motor that is 4" in length max....Restoring is pricey with original-equipment parts, but... a micro drill press doesn't take
much motor power, and 'chuck' can be an ER11 collet; that's not expensive.
Fixing up a very useful tool isn't going to be expensive, IMHO.
Micro-drilling, doing small holes, a 3000+ RPM drill press is nearly indispensable.
