- Nov 28, 2016
- 2,793
I took a day off from working on the Hendey lathe today... my old Buffalo Forge 21" drill press had two broken teeth on the downfeed worm gear...
I built the teeth up using the TIG welder and silicon bronze filler.
I have a 12 DP gear tooth cutter... I realized it was close enough to use to rough out the worm gear teeth, so I set it up on the horizontal mill and machined most of the brazing back, then hand blended what was left.
There are still several teeth with small chips on the corners, but nothing that will affect the functioning... I hope. The worst one can be seen in the pictures.
-Bear
-Bear
