Working with brass is very satisfying
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,666
We are having our house painted.
The owner saw my shop and asked if I could make some decorative brass screws??
Ah, yeah!
This is what he asked for. He said he couldn't buy anything at the hardware store that did the trick.
I'll make 10 of these for him. A little horse trading. 5/16" thread, 1 inch long.
I told him I could make acorn nuts, hex, not quite ready to do Torx or Phillips??
Nice. I can see how making brass clock parts would get addicting too
Click Spring makes everything look easy. He uses a lot of brass in his clock making profession..
Check out his filing techniques, pure genius.
Most brass I have been able to lay my hands on these days is steel with a brass plating. That's why I use a lot of brazing rod for the small stuff I make. Brass fasteners are almost out of the question, keystock can be found (sometimes), and Amazon has some sheet stock. For screws that size, he was doing good to stumble over someone that could make them.
Nice work Janderso. Brass is fun to work with, but like savarin said, the little chippers can be nasty! I have a set of drill bits with the cutting edges
dulled so the bits don't grab so badly and pull thru into brass.
