- Oct 6, 2024
- 27
Hi all, as i said in a previous post someone has shortened and moved the rack on my lathe. I am still having issues with the carriage movement and can only think of two reasons why.
1) the rack is in the wrong place (this seems unlikely to me because it moves about half way sweet as a nut)
2) mr bodge and bugger it has got some random rack from some where and hacked a bit off.
Hence i need to know the diametrical pitch to make sure that bit is right .
am i right in thinking that a rack is basically a round gear that has been straightened out ie if the length of the rack is 35" then the diameter of the "gear" would be 35/Pi. From there the dp can be worked out by the number of teeth on the rack + 2 divided by the diameter?
many thanks
many thanks
