For some time now, I had a "problem" with my lathe, in that the power feed screw worked, but the feed for threading didn't. I had figured that I had screwed up one time and run the saddle into the head of the lathe, and broke something in the gearbox. It's a Force International ML1440GH lathe, evidently pretty much the only F.I. lathe on the internet, but it's a semi-generic clone, so I googled for other ML1440 lathe manuals, found one with a gearbox front panel that looked like mine, and figured out how to take it apart, at least to take the front control panel off to see what's up inside.
And here's the gearbox insides, and the backside of the control panel:
And note to anyone doing something like this, and fiddling with the control settings with the panel off like this, some of the controls use a ball-detente setup to produce a satisfying "click" feeling in the handle for each gear position. With it apart, it is possible to rotate the controls past their limits, which will result in the ball being launched in a random direction.I spent around an hour going through the crap on the floor around my workbench before I found it (I was close to just giving up and buying a ball bearing or a bearing to cut apart to use)...
So, I fiddle with the gears, and eventually come to the realization that there was nothing wrong with the lathe (at least, not with the gearbox).
Here's the threading/power feed charts and control settings panel:
It turns out, I had the threading screw in neutral. If you look over the threading/power feed chart, all the entries for threading use JKLMN, while the power feed entries (two charts along the bottom), use P. From looking at the gear position you see in the first photo (top sliding gear on the right-hand side of the gearbox), that happens to be in the 'P' position, which doesn't drive the threading screw. So yay, there's no problem.
So, I can clean up the control panel mounting surface, maybe put on a bit of rtv and bolt it down, but I have two questions
1. What gear oil should I put in it. I've got some SAE10 and SAE30 non-detergent oil, but I can get other stuff if it should have something else
2. I took the arrow "covers" off the AB and CD knob (as part of trying to figure how to get the knobs off before finding out it doesn't come apart that way), and now I'm not sure which way the indicator is supposed to go for them.
