Work holding with single T-Slot
Cortez
Jun 4, 2018
12
I have a Burke #4 horizontal milling machine that only has a single T-slot. Usually, I use a vice clamped using T-nuts. What are some options for clamping when the work is too big for the vice? I have a piece that I want to put a slot in, but wouldn't something like strap clamps just get in the way of the horizontal cutter?
A picture of your mills table and what you want to fasten to it would help a lot in getting you some good answers.
You can make a fixture plate the bolts to the table with countersunk bolts and drill the plate as needed for clamping
You can use multiple clamps and remove/replace them as the milling progresses down the length.
You can use the t-slot as a v-block to align the part, but then you’d only be able to clamp at the ends; unless you use something like the fixture plate mentioned above.
It would help to see what you’re getting into. The beauty of a horizontal is like the shaper in that the force being applied is linear to the slot. So a shop made what they called a dog or angle plate as your stop at one end with toe clamps at the other end have done it for me. It all depends on how tall the work is. Shorter closer to the table is better but for tall stuff an appropriate angle plate as backstop has done the job too.
