- Jun 12, 2018
- 724
Are there any tips on how to make your workpiece inside the chuck of your lathe not wobbly? I'm trying to get it as straight as possible, but having no luck. I tried outer and inner jaws. I don't want to just "eye" it.
I'm trying to smooth a small aluminum flashlight's handle. Get rid of the knurling on the aluminum as well as the paint coating.
Also, what's the proper machinist term to use if a cylinder is "true" and if you indicate it, you get almost no movement on the needle? Is it conecentric?
