Hi everyone, last week I picked up a 3 Phase, Quincy QT-7.5 - 80, 2-stage compressor. There were 2 previous owners. The original owner swapped out the 7.5hp 3-phase motor for 5hp 3-phase motor and installed a 125PSI SD Pumptrol pressure switch.
My shop is powered by a 10hp American Rotary ADX Phase converter. I don't have the need to have this compressor running everyday or all day long. Only when needed to power pneumatic tools. I am a one person shop.
The only reason I can think of having this secondary on/off switch is to have essentially a kill switch that prevents the pressure switch from starting the compressor while the phase converter is not running.
I do not have any way of starting the RPC off a machine start switch. So this is all a manual process of starting tye RPC then starting whatever machine I am going to use.
Obviously I would have the RPC running prior to running the compressor.
WHAT I AM CURRENTLY WIRKINGBON AND HAVE QUESTIONS ABOUT:
The tank is rated for 200 psi and all high pressure relief valves are rated for 175 psi.
I have ordered a new pressure switch with a 135/175 on/off limits.
The motor controller is a Siemens 14DS-32A 3-phase 200/230 VAC
Max HP 7.5
Max Amps 27
Includes a Siemens SP 100 adjustable solid state overload relay CAT. NO. 48ASF3M20
My question is related to wiring the Siemens motor starter with secondary Siemens 49SBSB4 On/Off switch.
Why would there be duplicate on/off control switches?
There is a pressure switch
There is a secondary on/off switch added to the motor controller.
Secondly, how do I wire in the secondary on/off switch?
I am missing one wire from the secondary on/off switch. It looks like it needs to be wired between the two hots that run between the starter coil and the pressure switch?
This compressor has a pressure switch to control on/off based on pressure.
Can the additional on/off switch be wired to operate as an override or kill switch to disable the pressure switch to prevent tye compressor from starting if RPC is not running?
Thank you for any insights you may be able to offer.
Rick
Max HP 7.5
Max Amps 27
Rick
