Hello every one,
I am new to the site and electronics and need some help with wiring my Huanyang VFD router to my CNC machine. I am getting conflicting information on the net so I want to verify the wiring with some one who has done it before.
What I would like to know is as follows:
- There are 3 Pins on the router to use. The problem is they don’t tell you what North American color code wires to put into the pins
- Pin 1 = I think is black
- Pin 2 = I think is red
- Pin 3 = Not sure what it is. May be the white wire
- Please confirm or correct as needed.
- Connecting to the speed controller (PWM) from the router. They (Huanyang) suggest you use U, V, and W, on the PWM. Same problem, what colors to these junctions?
- U = I think is the black from the router
- V = I think is the red from the router
- W = Not sure what to use
- Please again confirm or correct.
- Connecting the PWM to 220 V power supply. They again tell you to use R, S, and T, connectors.
- R = I think is black
- S = I think is red
- On the web (one Place, tells you not to use the White wire in T but to connect it to ground in the PWM ground and leave T empty.
- Again, please confirm or correct.
- All green wires I think are to be connected to common ground on the casing of the box
- The last think is the water pump. It is 220V and they don’t explain if you need to put it into the water or have it external. I don’t want to put 220 V into water unless it is designed to be there
- Really need the help, don’t want to blow things up as other have or myself,
- Vic100
