OK, what I need to power up is a 1 1/2 hp 3 phase motor on a South Bend Lathe.
What I'm rigging up is a way to test to see if the motor is actually functional, then if it is I'm pretty sure I'm going to purchase a VFD as a permanent solution.
My proposed rig is I have a 5 hp 3 phase motor that I'm intending to use as an idler to convert my 220v single phase to 220v triple phase.
So if I follow what Richard directed:
Connect wire numbers 4,5,6 together and wrap with tape.
Connect 1 phase power from your electrical switch to the 3/ph motor to wires 1 and 7 and your 3 phase machine, tape up,
Connect the other 1 phase wire from your electrical switch to the 3 / ph motor to wires 2 and 8 and another 3 phase to your machine. Tape up.
Connect the 3 /ph motor wires 3 and 9 to the last 3 phase to your machine.
Do I hook the ground (3rd wire on the 220v single phase plug) up to the ground lug in the 3 phase motor's electrical box?........./QUOTE]
Okay, now I understand what you are trying to do.
Not positive but I think what Richard’s numbers mean are motor wire leads labels of a dual voltage motor? However the two links below are a couple of good “how to” articles that should help clear things up. George Carlson’s article (first link to HMS) includes some good wiring diagrams that should help. Note that in the diagrams grounds wires are not mentioned but must be included to avoid the “health risks”. If you connect the two hot leads (normally black and/or red) of a 220V home power lines to your idler motor leads and the three motor leads from your lathe motor to the converter motor leads. Then using a pony motor start or rope start as Richard suggests it should start and run. However it would not be balanced meaning that the voltage in the three lines between the idler motor and your lathe motor would not all measure the same or nearly the same voltage but would serve as a test of your motor. The articles describe how to make a button-start or self-start if you want to go that route.
Homework assignment read: http://www.homemetalshopclub.org/projects/phconv/phconv.html & http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
The VFD is the way to go in the end but a balanced rotary phase converter works just fine.
After you read and look at the diagrams the answers to your questions above will become clear.
In response to your question about the ground wire connection, the answer is okay if it is a true ground (green or bare) and not a neutral (white).
Benny
The Orphanage Never Closes
