I'm doing this on an Atlas 10F as well and am part way thru the process.
I have a Phase II from Enco but I'm sure you can find a CA source as well.
You want the AXA size for a 10F Lathe. The Phase II is an Aloris Clone and is well recommended (why I got it) It is a Wedge Type.
You can google the difference between QTCP Wedge and QTCP Piston and you'll get a quick understanding of them.
This link for Phase II shows both Versions:
http://www.phase2plus.com/details.asp?pr=QUICK_CHANGE_TOOL_SETS&id=52
This On-Line Seller seems to have Canada Covered for shipping:
http://www.industrydepot.com/phaseIItoolposts.htm
The Cliff Note version is:
A Piston Type pushes a Piston Out from the Side of the QTCP to PUSH against the Tool Holder an fix it in place.
Some People say this creates a BOW in the tool holder overtime and creates some deflection by the force required to fix the Tool Holder in position.
The Wedge has a Sliding Section that Jams the against Dovetail Slot effectively making the dovetail slot wider and holding using force in a different direction on the Tool Holder.
From what I've gathered in my research the actual Tool Holders are interchangeable between either model. It's the Post Itself that is different.
Look up (Google R.G. Sparber QTCP) Look in the Metal Working then Lathe areas of his web site. and you will come up with a very well written PDF file of installing a QCTP on an Atlas 12" Lathe.
There is very little difference between the 10F and the later 12" from the perspective of installing a QCTP.
I plan to make a replacement bolt for mine that will use 1/2 x 20 threads top and bottom with a center diameter of 14 mm because the straight 14 mm bolt seems to be just too tight for clearance in the "T"-Nut for the 10F Compound. This issue is clear to see in the PDF on Rick Sparber's site.
I have a post started on this. I'm waiting for some metal supplies to arrive so I can get started.
