Who make bronze nuts for Cross slides?
raykehrhan
Nov 8, 2014
12
Hello,
I'm restoring a cross slide and am looking to see if there is a company out there that makes Bronze nuts.. Anybody know of one? I'm looking for blanks that I can then fit and thread.. These are for Pratt whitney precision bench lathe compounds. Any suggestions appreciated..
Thanks
Ray
Just buy the Bronze Stock close to the size you need and make your own.
"Billy G"
Tom Ross makes feed screws and nuts for common machines and sells on eBay as tross96586. Also Roton Industries ( www.roton.com ) sells ground screw stock and nuts for same of various materials.
Hope this helps...
Jeff P
Tom does good work - little pricey but then what are the options for old machinery ? I bought a bronze cross slide nut and a lead screw for an old Sheldon from him. The cross slide nut, as you'd like, is a bit oversize so that it can be customized for your machine. I'd give him a shout since idjeffp has provided his eBay ID.
He's a nice guy and very responsive, just ask if he can help you out. He may not be able to because he likes to run these parts in lots, of course, but it's worth a shot. (I certainly didn't want to single-point a left-hand acme thread starting out with a 3/8 diameter bore, LOL !)
I once made a left hand 5/8 10 Acme tap for a cross nut, also made the lead screw. Our shop was too cheap to buy repair parts, I guess my time was even cheaper.
That's probably the only way I'd attempt to make a nut (although I might make three Acme taps, to take a little bit off at a time). If you had the knowledge and experience to make the left-hand tap and the lead screw, and your management thought that it was cheaper to make than to buy then you were undoubtedly underpaid - but I'm sure that you knew that at the time !
Just got a full set of crossfeed nuts and split nut for my atlas from Mike Neville on eBay. jayhawk machine tool. they are really well machined and work very well. took nearly all of the backlash out. I'm super happy.
