- Dec 18, 2019
- 7,429
I need to make a clamp to hold a dremel tool somewhat rigidly. This is to cut off some M2 rod to a precise length and to make a straight partial cut in it. At the moment, my mill is tied up while I wait for an end mill with a longer LOC. So it's out of action for a little while. But I have a mini-lathe. After rummaging through my stock, I came up with two ideas.
1. I have a piece of 4" x 4.1" x 1" 6061. I could grab it end wise (piece sticking out from the 4 jaw) and face off the end to about 4". Then I could bore a 1.86" hole in the center of the 4x4 face to fit the dremel body. Then I could drill and tap a screw to close the slot, which I would make last. Having the piece rotating like that seems weird, but maybe it is doable.
2. I have some 0.75" x 1.5" CRS. I could cut off pieces 3 inches long. Then face the ends, similar to the 6061 idea. Then I could clamp them together to form a 3" x 3" x 0.75" thick piece. I would use the 4 jaw to clamp the pieces together. Then I would bore the 1.86" diameter hole through the "crack" in the center of the 3x3 face. I guess I could grind one of the legs of the "U" to make an effective slot. I would put in two screws to hold it together.
Which idea is better? Or none of the above? The ideas seem plausible, but I'd like not to do something really stupid. Stupid increases your chances of getting hurt. Got any better ideas? Have mini-lathe, and hand drill. Might be able to set up drill press. It's been sitting unused on the floor since I got the mill. This doesn't have to be fancy, just good enough to a) clamp the dremel, and b) allow me to grab the dremel clamp in an (aweful) xy vise.
