- Oct 19, 2020
- 160
I have been becoming familiar with my 1973 South Bend 10K lathe. One thing I would like some advice on is when it is OK to move the levers when the chuck is spinning. It seems that this is not a simple question since there are several factors to consider. So I made a table and filled in the Middle column with my best attempt at Y or N. Any advice is appreciated. I would prefer not to turn the lathe off every time I move a lever for convenience but I am more interested not damaging my machine. Thanks.
Lever Description | OK to change when chuck is spinning? (Y/N) | Note |
Feed change lever up position | N | On apron Longitudinal feed Assuming lead screw is turning |
Feed change lever middle position | N | On apron Threading Assuming lead screw is turning |
Feed change lever down position | N | On apron Cross feed Assuming lead screw is turning |
Threading lever down position | Y | On apron Half nut disengaged Assuming lead screw is turning |
Threading lever up position | Y | On apron Half nut engaged Assuming lead screw is turning |
Lead screw lever up position | N | On head stock Reverse lead screw |
Lead screw lever middle position | N | On head stock Neutral lead screw |
Lead screw lever down position | N | On head stock Forward lead screw |
Transmission levers | N | Bottom of head stock 5 positions left lever 8 positions right lever |
