Which change gear to use.
Ilyessa
Aug 28, 2018
13
I was recently given a Chizhou HQ400/3. Was helping an old friend clean out a shed.
My question is dose anyone know where I can find a chart,table,book that tells me which change gears to use to cut threads.
Thanks.
Ilyessa.
if you figure out what thread pitch the lead screw is someone here will be able to figure out the math. I'm not that smart
If you know the leadscrew pitch, likely the gearing would be the same as any other similar lathe with the same pitch leadscrew; no math necessary.
You might take a look at the Smithy brand documentation, they look similar
-Mark
