I thought there was a sticky thread on threading but can't find it. If there's one then please delete this and point me in the right direction. I'm trying to do threads and I'm getting oh so close but I'm still not there. The goal is to put about .75" of 1/4-28tpi thread on the end of a 3/8" rod. The best I could do is the first pass where it outlines the threads and after that it just all fell apart. I decided then to try and make something easier like a bit fat 3/4-16. I'm using a threading insert that I lucked upon. I've got the layout down pat, the feeding part is good, I've almost mastered the half-nut on/off.
I was able to make a decent 3/4-16 thread but then I think I went just one pass too far and I can screw a 3/4x16 nut onto it but it's very very loose. So I'm down to a few small questions.
1. Major diameter. For a 3/4x16 do I start with 3/4" rod or slightly fatter? (I guess the same question backwards applies for internal threads.)
2. Thread depth. After the first pass I used the little arrow-shaped tool to check thread distance and it was good. Then as the threads got deeper I checked with the thread gauge (the one that has 50 different pieces and you pick the one with the number of teeth you want to check). Was I supposed to stop when the thread gauge didn't touch bottom, when it just touched everywhere, or some other criteria? This was my biggest problem when I tried the 28tpi. It seemed like one pass just wasn't enough but 2 was way too much no matter how little I moved the bit in. I've got to learn when to stop cutting.
3. 60 degree on the cutter. Is that for ALL standard threads (not counting the acme, the whitworth, the metric etc.) or is that just for the bit fat threads like 8tpi or 16 tpi? Before I found the threading insert buried in a drawer I was trying with a free-hand ground HSS bit that was probably not realy exactly 60 degrees and may have been part of the initial problem I was having.
4. I can release the half nuts, move the carriage out of the way, stop the lathe, let it coast to a halt, and then check with a real nut. If I do that and then start it back up then I can keep threading right? (Meaning is the whole leadscrew and dial thing all still in magic alignment?)
5. I heard there was a way to do threading in one pass with something different than your usual cutting tool - like part of those big threading tap and die sets where the dies are in four pieces. Was that a dream or is it real and if so where can I get more info?
Thanks in advance for any help. Remember I'm a newbie and I'm a visual learner so a picture would be a great help. A video would be even more tremendous. And a pop-up book with pull-out tabs and maybe even scratch-n-sniff would be perfect.
thanks
Joe
thanks
Joe
