I've got a '75 model with a step pulley J-head. Is it known as a "Series 1"? It doesn't say that anywhere on my machine but the M105 Series 1 manual that I downloaded seems to match my mill.
Looks like the "Series 1" refers to the manual machines produced since 1938 (as opposed to the BOSS and other CNC machines). I didn't read the full article at lathes.co.uk, but it may have more info there
I know that a Series 2 Bridgeport is a bigger machine but it also says "Series 2" right on it. I was wondering if ALL of the "standard" BP mills were considered to be Series 1 or if that title was applied only to the little BPs after a certain date, or some that might have extra features.
I'm putting a 74 series one jhead basket case back together. I got the excellent book " A Guide to Renovating the Bridgeport Series 1 "J" Head Milling Machine. They also have one on the 2j and 2j2 models. they are a wealth of info. Your series 1 will accept a j, 2j, or 2j2 head. The m105 manual appears to match my machine as well. What do you need to know that's not in your book?
My machine's number doesn't end with an M but it seems to match the Series 1 manual that I downloaded. What's the difference between the "non-M" mills and those with the M?
I noticed two things about the manual: It was printed in 2010 & It only addressed the 2J head. This leads me to two conclusions, either or both of which can turn out to be completely wrong.
Either the Series 1 designation is only applied to machines equipped with 2J heads -or- The stepped-pulley 1J heads were no longer being produced in 2010.
