Many lathes have a pressurized oiling system for the ways. You pull out the knob and the springloaded piston pushes oil through small tubing to the lube points. With oil in the reservoir, it should not spring back immediately, but slowly as the oil is moved. With a dry reservoir, it will spring back quickly. It should be pulled out periodically during use of the machine.
