- Dec 26, 2016
- 2,108
I'm working on a piece of Aluminum rod 1.9" in Diameter,3.5" long I want to machine the middle part 1" wide, to a diameter of 1.25", 1.187" away from either ends ,the workpiece will have a "dumbbell" shape.
I have been using my triangle carbide insert ,it does the job but I'm taking .003" on each pass, it'll take forever to get to the desired diameter.
Should I cut two beveled reliefs on either ends first and then machine in between?what cutting tool is more appropriate.
I'd appreciate your help.
