So this is my first time using a center in a lathe and having a weird cut almost like its out of round or the metal is twisted(i know its not.. the metal is 0.656 drill rod, i have 0.002 runout at spindle end, have 0.004 at the tail stock end. Now tail stock was out of alignment, and tried getting it close using two centers and matching the points up, so its most likely off. But i tried moving the alignment a tiny bit to remove that runout and just keeps jumping around.. my main concern is the cut in the pictures, its about a 0.010 cut. Barely cutting at tail stock end and cutting at spindle end.... Have any pointers for me?
In the pictures its that diagonal line you can hardly see. Just a weird twist type of thing going on..
