- Mar 30, 2013
- 35
i picked up a 109 craftsman and I debating between a 1/2 and 1/3 horse motor not sure what I should try to find anyone know what they came with new?
I used a 3/4 hp on my 6" atlas because I happened to have one. As I recall, there was a 1/2 hp on the lathe when I bought it used in 1970. Looking at the manual , the rating on the lathe is 3050 rpm in the high range on the primary pulleys. It appears that the stock primary pulleys may have been changed by the previous owner as it now has single sheave pulleys. With the current pulley arrangement, the lathe maxes out at about 1100 rpm.AA made several lathes that Sears sold and there is no way of knowing which one you are asking about. But the first period (1942 +/-) during which Sears sold AA built lathes, they recommended a 1/4 or 1/3 HP 1750 RPM motor, which had to be purchased separately. After WW-II, they recommended a 1/4 HP minimum, and for an additional $13.50, sold the lathe with a 1/4 HP sleeve bearing motor. Note that the same motor today would have an advertised full load speed of 1725 RPM. And I would get one with ball, not sleeve, bearings.
The Atlas 618 has a spindle about twice the diameter of any of the AA lathes. But still, putting a 3/4 HP motor on it is a waste of money and asking for trouble. It isn't strong enough to stall a 3.4 HP motor without most likely breaking something. In your case, regardless of which AA model you have, the same is true of a 1/2 HP motor. So to answer your question, I would put a 1/4 HP motor on it, and if you stall it, you probably won't bend the spindle. And don't use a 3450 RPM motor. The motor pulley diameter required to safely run it on either brand of lathes is too small for the belt size.
