Curiosity strikes and I figured I might as well see what others think.
I am always in the perception that bigger is better. and while the AXA tool holder can hold up to 1/2" tool bits I figured those will be the most rigid = smoother cuts. so I got some 1/2" bits.
I also had some 3/8 (or maybe it's 5/16") cutters previously that I was using, and then I got some 1/4" bits for use in the boring bars and flycutter and tangential holder I made.
I am not sure if I find any major difference in the quality of the cuts I'm making on my 10" clausing lathe and was wondering - should I just adapt to a common size cutter that would work for everything (say, 1/4" cutter will fit in boring bars, and can be used in the AXA - although it would be on the smaller side of things), or pick and choose and use the largest I can fit in the tool holder (1/2") and the 'right' size for boring bars (1/4") etc?
what do you guys do?
