Beginner's question...
I have a cheap 115 piece HSS drill bit set. Works fine on softer materials. But there are steels it does not work on. (I do not know how to evaluate steel--but I am working on old railroad spikes now. Carbide end mill works on it. My cheaper HSS end mills do not.)
My drills bits do not drill the railroad spikes.
So, how do I figure out what drill bit set to buy that can work on such harder steel?
I look at HF say and see https://t.harborfreight.com/115-pc-...886.html?utm_referrer=https://www.google.com/ for $110. (Yeah 20% coupon is available).
But also I see https://t.harborfreight.com/115-pc-...620.html?utm_referrer=https://www.google.com/ for $40. There must be a real difference. How can I tell what each can drill? And how about http://littlemachineshop.com/products/product_view.php?ProductID=3418&category=-456343308 for $500. So, how is that different?
And for $945 https://www.amazon.com/Cleveland-C7...83604&sr=1-1&keywords=115+piece+drill+bit+set
Are there carbide sets too?
So, I need to select length (Jobber seems good for my PM25 mill).
I need to select tip angle (why 118 and why 135?)
I need to select material/brand/grade. How does one make this selection?
And, in particular, if I want to drill holes in hard steel what should I buy? (I have given up on drilling into ball bearings. But as my carbide end mill does well on the rail road spikes that suggests it is doable.)
Drill bit selection must have been covered before. Any pointer to some such old thread much appreciated--my search did not turn anything up.
-Bill
-Bill
