- Jan 25, 2015
- 2,558
Argo cover (for the most part) finished and out doing its job:
Feb 17, Nova Scotia, +10c and heavy rain. It feels like getting shot with a million bb’s all at once if you step outside.
Unbelievable. Just crazy weather this year. I’m beginning to wonder if I needed the snow tracks at all…..
I also found out why the lh brake/steering locks up when the temp drops below freezing. It seems water is somehow getting under the body and dripping on the tops of the two mater cylinders.
The water somehow managed to get inside the master cylinder (despite having a seal) and because the brake fluid is dot 5, it was sitting there as a big slug of water. Freezing temps would turn it into ice and lock up the master cyl piston.
So I drained the master, filled with fresh dot 5 and flushed it out to the caliper. Still need the temps to drop to make sure that was the problem.
So I’ll need to do something to shield the two master cylinders from water dripping on them. I think I’ll just make a snap on cover with a drain line and print it off in ABS on the 3D printer.
