One of the steering brakes wasn’t working in my argo:
so I hauled it into the heated garage today and started looking. Turns out the brake pads had somehow become oil soaked. A quick check revealed no oil leaks so I wiped the disc with acetone and soaked the metallic pads in acetone as well. Then a good burn off with a propane torch to cook the remaining bits of oil out. A good sand on a flat plate to give them a final clean and back in they went.
then, while removing the front drive chains to install the snow tracks:
I noticed the engine shroud had a little grass hanging out.
A deeper look and sure enough, some damned mice had turned the engine into a mouse condo.
So then on to the major pitb of removing the engine shrouds to vacuum out the mouse condo. In the process, found everything else (air filter housing, battery box, etc) was also packed solid with leaves, grass and anything else they could drag in there. Of course, everything was also covered in mouse **** and crap.
luckily, nothing was chewed. I don’t think they were in there long enough to get to that point.
I hate mice. I can’t believe such a small animal can create such massive damage…
