What is this wire on the Vise Jaws?
oskar
Nov 24, 2013
268
The attached picture shows a piece of wire on one side of the vise jaws holding the work. I have seen this practice in other videos and I wonder what is the purpose of this wire. To my opinion it’s not safe
Nicolas
The wire will allow for any irregularities in the material. This way the stock will be flat to the fixed jaw. Thus allowing the top of the stock to be machined square with fixed jaw. Use this procedure till all sides are square to each other. You can use aluminum brass or steel for the wire about 1/8" diameter is usually sufficient to allow the wire to conform to the rough side of the material.
Hope this is as clear as mud. Maybe others could explain it in simpler terms.
This technique is used to square up a piece of stock. Once you take a cut off your stock you place the fresh cut on the fixed jaw. When you place the piece of malubal wire in between the moving jaw and your work it allows the work piece to sit flat against the fixed jaw without your piece being parallel yet. Once you take your cuts and have two parallel sides the wire is not needed.
It’s there to take the irregularness out of the part so you can clamp in vise and it will be secure.
I use a popsicle stick similarly- Jan and Dean would be proud
Very interesting and thank you all
JRP, the link is an excellent tool for a beginner, thanks
Nicolas
Glad you liked it. I spent several hours looking over all his projects.
For the size of most of the small work I do, I use the solid copper wire from a standard 12 or 10 AWG romex cable. The ground is easiest, but the white and black are also easy to strip out. Easy to bend it to hold on the jaws. Professional machinists I know usually have a couple of larger ball bearings with one side ground a bit to use for one side of irregular work.
That's a very good tip, thanks. I have lots of 12 AWG around my garage
Nicolas
