The attached photo is from a friend, it's a sine-bar that his father made, with a mysterious tooling plate and some pins ("stubs"). Can anyone identify the use of the plate and stubs?
Here's what he had to say:
The stubs are not attached by the cap screws.
They are set in bores like the upper right.
Not really sure what the cap screws are for.
They do not fit the threads in the plate.
The stubs are threaded across to be attached to the bar.
The longer stub can be installed on the bar so it will pivot on the plate. That's how I originally found it. I suppose for horizontal angles. Maybe the use a parallel to make the reference surface?
TIA,
GsT
TIA,
GsT
