- Jul 1, 2012
- 1,356
Hi Everyone,
I wrote this few days ago on another site I write on and thought I would share it with you.
Someone asked "What is scraping anyway?"
my Answer:
It is the precision fitting of ways on a machine tools and it provides even oil lubrication film on the ways (also used on Babbit and bronze bushings bearings, etc. Over the years it has been discovered that hand fitting or scraping of the ways is the most precise method so machines wear and function properly. We use a carbide tipped "scraper" that resembles a file or wood chisel. We scrape pockets approximately .0002" deep to form weight carrying high spots and the low spots are for oil. A good scraping job resembles a chess / checker board one spot is high and the next spot is low. Our goal is to get 50% high spots to carry the weight and 50% low spots for oil.
We fit the machine way clearance from .0002" to .001" so oil can squeeze between both sides of the way surfaces so the ways move smoothly and do not wear. We also test the squareness and alignment using levels and gages.
It's a trade, but it is pretty easy to learn if your mechanically inclined and have a good teacher. Scraping is easy but knowing where to scrape and how much to take off is the hard part. I also say in my DVD, start small on a surface plate and then start an easy project like a lathe compound.
Most conventional machines like lathes and mills are scraped to an accuracy of .0002" per 12" and straight edges and jig bore super precision machines are scraped to .00005" per 12". The high spots are classified as High Points per 1 sq. inch and on the conventional machine we try to get 12 to 20 point per inch (PPI) and jig bores / super precision we try to get 38 to 42 PPI If you ever look at the ways of a Bridgeport you see 1/2 moon spots, well those have 2 functions, the main being extra deep oil pockets plus they look nice. they are approx .002" deep.
I was talking to a reader and he asked about a Scraping Seminar in the UK sometime, so I just wrote a friend of mine in NE England who works at a used machinery company and asked him is he could host a class next summer. I await his response. So all who live in the UK pass the word and let me know if your interested in learning to Hand / BIAX power scrape, 1/2 moon flake and learn to repair your machines. When we have more info I will advertise it on the area Tony talked about.
Mechanics that scrape are called Machine tool builders, fitters, or machine rebuilders. I am a Journeyman Machine Tool Rebuilder. I apprenticed under my Father who lerned from a German born Journeyman during WW2 a a Defense Plant here in MN. I started to rebuild machines and scrape when I was a child...50 years ago...I am now 62 and have been teaching scraping for over 30 years for companies like GM, Timken, Cummins, John Deere, worked with several new machine builders in the USA, Europe and Asia; Spinner, Hardinge, Kent, Paragon, Hartford, Sharpe, Chevilier, plus taught several hobbyists and home machine shop owners.
I hope to help all of you repair your machine tools on his site. I like this site as there are no bullies allowed as seen on other sites.
There are others who teach scraping, I am one of them.
my Answer:
