- Nov 17, 2020
- 1,723
that's what i wanted to know.. thanks.. i couldn't find one that looked like it would fit..Nothing is missing, that is an indicator for some special application, you could get a "lug back" to use it for most other purposes.
yeah.. i am more curious about how it is supposed to be mounted with that kind of back more than anything now.I've got no idea what you're "supposed" to do with that, but they are out there in several brands. Here's one....
PT06878M Adjustable Bracket (#1/4-20 Thread) Indicator Back for 655 Series Dial Indicators
Adjustable Bracket Back for No. 655 Series.www.starrett.com
Short of a "proper" application for it, It looks to me like it would simiplify the process of making your own specialty mount, on lathe ways for the carriage or cross slide, mill tables, or whatever else. .
it's more like, which back i will put on it, then that will dictate the use for it..What purpose do you intend to use it for? That will narrow mounting choices.
i was intending to do the swap.. still have not found the answers to the other one (the adj drop back)Scratch that... here it is...
Mitutoyo - Adjustable Drop Indicator Back
You can swap it for the Lug Drop Indicator Back
