To me a wire gauge means just that, a wire. So do wire gauge reamers not have cutting capability?There is no substitute for having the right reamer on hand when you need it. I agree that the over/under fractional set will be the most useful, but wire gauge and alphabetical sets provide good options for on-the-fly fabrication, too. Just hold out for those really good deals, because retail sets can be ridiculously expensive.
Well said Mr. Pontiac.There is no substitute for having the right reamer on hand when you need it. I agree that the over/under fractional set will be the most useful, but wire gauge and alphabetical sets provide good options for on-the-fly fabrication, too. Just hold out for those really good deals, because retail sets can be ridiculously expensive.
Wire gauge reamers cut like any other. I'm just advocating that having a set on hand can provide you with a nicely finished hole in a size that may work for any given project if the sizing is right. I was working on a project with two fitted parts last week where I wanted a reamed hole and the size of the assembly just needed to be within range of a spring diameter. Turned out a size W was a good fit, and I had that on hand. Other times, a size is very specific, so I have to order those reamers ahead of time.To me a wire gauge means just that, a wire. So do wire gauge reamers not have cutting capability?
Can you just explained to me what the designations mean? wire gauge reamer, number reamer, alphabet reamer. ??? All I get is the standard imperial sized and the metric sized reamers. I'm assuming a number (#) reamer is associated with drill bits that go by, for example, #6.Wire gauge reamers cut like any other. I'm just advocating that having a set on hand can provide you with a nicely finished hole in a size that may work for any given project if the sizing is right. I was working on a project with two fitted parts last week where I wanted a reamed hole and the size of the assembly just needed to be within range of a spring diameter. Turned out a size W was a good fit, and I had that on hand. Other times, a size is very specific, so I have to order those reamers ahead of time.
