- Dec 18, 2019
- 7,320
I have a spindle indicator holder for my PM25. Since there is no spindle lock on a PM25, there is nothing to prevent slight movement when sweeping a surface. Also I don't like tearing down what is currently in the spindle to take a measurement. I'd like something more like an Indicol. Since there is a DRO on the quill, the body is much wider in diameter than normal. I measure it to be about 78mm or so. This is a little wider than 3" which puts it in the more expensive class of Indicols. What solutions have you come up with? I have a LED angel eye light magnetically installed on the bottom of the spindle, so I don't want to lose that. Definitely need the light. Any good solutions?
After a couple of hours, feel a little silly. My spindle light is covering the area where an Indicol could fit. Think the answer is probably a redo of the spindle light, or a serious modification. However, I am interested to know if those of you with quill DROs and spindle lights solve the problem. Can you have good lighting and room for an Indicol? If so, how did you do it?
