Thanks for asking, now maybe I’ll know where my stuff is! My tooling is spread all over, but is “somewhat” organized. Everything in drawers is at least labeled though my organizational skills need some work. For example, I have Heimann transfer screws in with stones . . .
Most of my milling machine and general layout “stuff” is in a HF tool box which sets next to my mills. Also have a roll away with more “stuff” like broaches, taps/dies, hand tools, files, measuring tools, etc. Both of my lathes have HF roll around tool boxes dedicated to each machine. I also have drill bits, end mills and taps/dies in drawers in a storage cabinet. Also have a storage rack for the heavy stuff like dividing heads, rotary tables, Bridgeport right angle attachment, etc. Didn't take pictures of it, but have a roll around workbench with a surface plate, height gauges, Jo blocks, etc. I also have an Atlas MFB mill on a rolling tool cabinet. Didn't photo it either but it's organized much like the rest of this stuff. Here we go . . .
"Miscellaneous" roll away tool box that sets between my lathes and mills:
Loctites, lathe tool holders, centers, broaches, mic's, DTI and snugs
Transfer screws, stones, mic's, dividers, compasses, etc.
Calipers, groove mic, inside mic, 0-3 digital mic's, DTI
Drill bits and files
Expanding mandrels, letter/number punches
Carbide drill bits, extra inserts, boring bars
Taps and dies
Missed a drawer with pliers, punches, wrenches . . .
More taps (English and Metric set on top of each other), pop rivets
Screwdrivers, Allen wrenches, and a Starrett 196
Drill bits, pop rivets and RG&G Gatling Gun fixtures
Dupe picture . . .
Broach sets, loose broaches and bushings
Milling machine roll away tool box
Reference books, screw machine drills, over/under reams,
15/32" - 1" drills, height gauge, DTI on an indicol
Writing utensils, deburrers, batteries, calculator, punches, tweezers
reamers
Laser center finders, radius end mills, tapered end mills, center/spotting drills, edge finders, wiggler
Carbide end mills, countersinks, keyway cutters
End mills
Jacks, 1-2-3 blocks, boring head, mill chucks, gear cutters/arbors, V-blocks
Bottom mill cabinet:
Mic's, squares, scales
Calipers, protractors, shim stock, small hole gauges
Indicators, 3 Interapids, Starrett DTI's, angle gauge blocks, RPM meter, BP right angle arbor
Wavy/adjustable/1/8" parallels, 5-C collet blocks, clamps
Blake co-ax, Mitutoyo 0-100mm digital mics
Thin parallels, more end mills, clamps
Face mills, jacks, counterbores, shackles, misc. BP parts, angle vise, depth mic
Grizzly G0709 lathe tool box:
1/16" - 1 1/8" 5-C collets by 1/64", misc. square/hex collets
0-6" depth mic, drill bits, 6" calipers, etc.
Inserts, DTI, Indical, Rockwin knurler, depth indicator
0.2 - 2" inside mics, 0-3" screw pitch mics, 0-3" digital outside mics, calipers, gauges, etc.
Steady rest, follow rest, dogs, face plate, spiders, etc.
Clausing 5418 lathe tool box:
5-C collets from 1/8" - 1 1/8" by 1/32". 3-jaw, drill bits, 6" calipers, misc.
Inserts, telescoping gauges, center drills
Calipers, indicators, 0-3" digital mics
Face plate, dogs, 0.2 - 2" inside mics, 0-2" screw pitch mics
Storage cabinet drawer with more drill bits, tenon cutters, etc.
Taps and dies
End mills, lots of end mills . . .
Pretty unorganized storage rack. Has angle plates,
dividing heads, mill vises, rotary table, HF rotary machine,
1/4" - 1" NF/NC tap/die set, spotting drills, center drills,
tool post grinder, mag bases, 24" calipers, Jorgenson center mike (correct spelling)
BP right angle attachment, Quillmaster, boring bars, Allen wrenches,
large V-blocks, probably other stuff I bought and forgot where it went . . .
Bruce
