What Did I Do Wrong?
lcorley
Nov 16, 2014
56
I just got my PM25MV up and running.
My 1st project was this wrench for removing wire wheels from my angle grinder.
I started with a 2 1/2 wide 1/4 hot rolled strip.
I cut the handle to rough size with a plasma cutter and roughed out the notch with a bandsaw.
I clamped the wrench on edge in my vise and milled the handles smooth.
I didn't go well. I used a 1/2" mill at 150 rpm.
I dulled 2 of them on the ends.
The mills were HSS from HF
www.harborfreight.com/20-piece-titanium-nitrade-coated-end-mill-set-5947.html
I though I might be turning too slow so I looked it up.
I was, so I tried a 9/16 mill at 700 rpm, dulling it as well.
I cut the mouth with the wrench clamped flat in the vise.
I used the 9/16 mill at 700 rpm. It worked better.
Can anybody give me some advice here?
Thanks in advance.
Leon
I think you should have been using the angle grinder to get past the hard scale left by the plasma torch, then mill if needed. The proof of this is milling the band saw cut vs. the plasma cut.
I've had pretty good luck with the HF end mills. I wait for the 20% off coupon to buy them.
700 RPM seems a bit high for a 9/16 in steel unless you are using flood coolant.
Thanks in advance.
Leon
Hot rolled steel has an oxide coat that is hard on HSS tooling. I remove it first, either by abrasion (grinding, sanding, etc.) or chemically (muriatic acid).
The plasma cut edges may have hardened. There is enough carbon in hot rolled to harden the steel and the rapid cooling as the torch moves away is sufficient to quench the steel. I have no experience with plasma cutting but this certainly happens with flame cutting. I grind the cut edges back to parent material before machining. You could also use carbide.
I also don't trust anything with a cutting edge from HF.
Bob
Thanks for the comments.
Here's a pic of the worn end mills.
I plan on replacing the 1/2" with carbide.
Do you reckon the interrupted cutting on the edge contributed?
Leon
Interrupted cutting with an end mill does not hurt it at all, by their nature the cut is always interrupted except when plunging..
I'm pretty sure what killed the end mills is the very hard scale left by the plasma torch.
When I have to machine scaly material I try and use a flycutter if I can to get thru the scale. Pretty cheap to touch up a HSS bit as opposed to trashing an endmill.
michael
Would a flycutter have worked on the 1/4" edge of the wrench?
I thought they were for large areas.
regards,
Leon
The skin on all metals must be considered before machining it. Hot rolled and any metal cut with high temperature will leave unknown metal surface conditions that can ruin cutters. You either cut underneath the skin of the metal or remove the skin first (typically with abrasion)…Good Luck, Dave.
You want to use carbide tooling in such an unstable machine? Good luck.
I would not try that in a fairly recent Bridgeport knee mill let alone a hobby machine, save your money and stick with HSS tooling, you can buy 5 or 6 HSS endmills for the cost of the one carbide tool that you will destroy immediately.
Your Mileage May Vary of course
