I got to be honest here, in the past when ever I needed to cut any metal I would use abrasives. Well I got a used 4X6 chinese bandsaw a couple years ago and I am not sure if I am using it proper. First of all, how tight should the blade be on it? I don't know if I had been tightening it too tight before but I seemed to break blades on it on a regular. I don't know if they were too tight maybe? Also on the down feed there is a spring on a rod you tighten to adjust the down feed. Do you just adjust it so the blade won't catch during the cut and stop the saw? Can I remove the spring and rod and install a hydraulic down feed assembly? Or do you need the spring and the hydraulic down feed? I see bigger saws with both, but I guess they are probably twice as heavy. Thanks for the guidance everyone!
