Weldon shank tools?
dabear3428
H-M Lifetime Diamond Member
Jun 22, 2023
703
if i have a tool holder that is set up with a set screw it is intended to engage a weldon shank? or can straight a shaft tool be used in the set screw tool holder?
Any straight shaft shank can be used . Grind a flat on the shank to engage the set screw . Make sure it is engaged by pulling the tool towards the cutting surface .
This.
Running a straight shaft without a flat can head to marring the shank and cause trouble in removing the end mill later if not making it a permanent fixture if it slips and galls the shaft.
