- Feb 2, 2013
- 3,957
i'm in the middle of an idea,
inside of building more junk art, that will require holding parts in different attitudes and axes to weld the parts together.
i had a few pieces of stock lying around, and the will, to make the positioning arm.
i use (read :ABUSE) my little Black & Decker Workmate for everything portable.
it's a table, a vise, a lunch table, a welding surface, a drilling surface, and assembly jig - all rolled up in 1 !!!!!
the workmate has pre-drilled 3/4" holes on the deck, i'll use this feature in the fab process.
(when in welding mode, i use a sheet of copper as a heat shield and welding conductor.)
the positioning arm was made from a 22" x 5/8" aluminum rod, a 12" x 1/4" 304SS rod ,
a 1-1/4"od x 3/4"od x 5/8" id step bushing turned from reclaimed bronze drilled/tapped to 1/4-20,
a fabricated 1"od x reamed .626"id 303SS collar-drilled /tapped to 1/4"-20 - the 304SS rod was welded to the 303SS collar with E309L-16 rod,
a 1/4"-20 knurled thumb screw/allthread combo for the lower bushing stop
the top stop has a 1/4"x 20 x 1" bolt as the attachment method
this positioning arm will surely be a help in the upcoming projects, i hope to share them very soon!
as always thanks for reading!
